92 F150 no start
Old Mar 2, 2010 | 09:34 PM
commanderpuppy's Avatar
commanderpuppy
92 F150 no start
I have a 92 F150 4.9 that starts on starting fluid. I all ready tuned it up - motor craft plugs & wires. New fuel pump,Fuel Filter & pressure regulator.Any ideas ? Any One !
Old Mar 2, 2010 | 09:44 PM
subford's Avatar
subford
You would then need to check the fuel pressure at the fuel rail on the engine with a fuel pressure gauge.
Short pin #2 to Pin #6 of the EEC Self-Test Connector with the key on and the gauge should read between 55 & 60 PSI fuel pressure.
If the fuel pump relay does not click when you do this try grounding pin#6 and if it clicks then you have a bad ground to the computer.
If you have the fuel pressure then check to see if the injectors are firing with a noid light, if they are not and you have power on the Red wire from the PCM Power Relay with a test light then change the PCM computer. You can check this wire at any injector.
