need help fixing 4.9
Old Mar 2, 2010 | 05:29 PM
lillbro11's Avatar
lillbro11
Question need help fixing 4.9
88 f-150 4.9/manual trans.
I just need to know what to check, test, or change.
KOEO codes
24- air charge temp or vane air temp out of range
84- EGR vacuum solenoid or vacuum regulator or shutoff solenoid failure
Memory
33- EGR valve closed/ erratic or has insufficient flow
KOER
44- Thermactor Air System failure
Old Mar 4, 2010 | 11:55 PM
lillbro11's Avatar
lillbro11
I just changed the
EGR valve
EGR valve position sensor (EVP)
EGR vacuum regulator (EVR)
and I'm still getting the same codes.
what could be causing this?
