Aerostar Ford Aerostar
Thermostat question
Old Jan 21, 2003 | 05:58 PM
saco2's Avatar
saco2
Smile Thermostat question
I have a 96 4.0 aerostar, once I reach operating temperature my thermostat fluctuates from just above cold to colder it never reaches the center of the gauge Winter or Summer. Is the thermostat easy to change. Or does anyone have any other idea?
cold in the northeast...
Old Jan 22, 2003 | 10:34 AM
aerocolorado's Avatar
aerocolorado
Thermostat question
Ease of change is relative to how you want to approach it. On the 4.0 the outlet housing the thermostat is directly behind the alternator. You can change out the thermostat without removing the alternator but the access to the three outlet cover bolts is very limited. Drain off 2 quarts of coolant beforehand and remember to pick up a new o-ring gasket with the new thermostat. There are several heat ranges available for this engine. I currently use a 195 degree thermostat and the gauge reads about the "N" in NORMAL.
Old Jan 22, 2003 | 11:09 AM
Bob Ayers's Avatar
Bob Ayers
Thermostat question
You will find that the Motorcraft OEM thermostat from Ford
will last longer, and maintain a more constant temperature
than after market replacements like Stant, etc. ....
Old Jan 26, 2003 | 02:06 AM
arostar's Avatar
arostar
Thermostat question
Hi i got a 92 van with 4.0 engine it will not get hot in there its got dual heat to.You could try a new raditor cap if they dont seal good they will lose pressure just my 2 cents
