Sponsored by: Auxito
engine missing during accelration
Old Mar 2, 2010 | 09:23 AM
Schuby's Avatar
Schuby
ok...this might be a long story, but here goes. I have 2000 F-150 man_tranny 4.6. It has 140,000 mi. It has set for about a month with out been driven. When i drove it it felt like it had a cylinder misfire. In the past i have had water leaks coming from black cowl where it meets the firewall and it did the same thing but much worse, the engine light would come on. As of now the light is not on, but what gets me is that it does it when when im going about 70mph but onlywhen going uphill ( i guess when under more stress??). The only other time it happens is under hard acceleration around 3000rpm range. It runs fine other than that. I put new spark plugs in at 110,000(motorcraft). I used seafoam 2 months ago before the sitting period. Any ideas to what it might be...im thinking of replacing plugs again or possibly new fuel filter.
Old Mar 2, 2010 | 10:23 AM
SteevenH's Avatar
SteevenH
Check the #4 COP. It's notorious for getting wet and going bad. Some say you can't do this
but I just did; Have someone sit in the cab and with all the breaks on , put the truck in reverse and bring the rpms up to about 1000
and start disconnecting the COPS. I bet when you get to #4 you won't detect any changes in
how the engine runs. If so , continue disconnecting the COPS . I bet one of them is
bad.
Old Mar 2, 2010 | 11:03 AM
redwood's Avatar
redwood
You can also use a code reader and check for pending codes that haven't tripped the check engine light yet...
Old Mar 2, 2010 | 11:21 AM
SteevenH's Avatar
SteevenH
I've been told that a code reader with mode 6
might pick up the code but unless your CEL is on , you won't get any codes . I ran into that
problem. Skipping when accelerating but no
CEL , thus no codes .
Old Mar 2, 2010 | 12:54 PM
redwood's Avatar
redwood
A couple of weeks ago, mine started missing. It was really bad in overdrive. I drove it like that about 15 miles to the house. No check engine light. I got my code reader, which is JUST a reader, not a scan tool, and hooked it up. I had 2 pending codes. One was for a cylinder #1 misfire, and the other was for a misfire in the first 1000 revolutions at startup. It never tripped the light. The codes were listed on the reader as pending. I replaced the coil on cylinder 1, cleared the codes with the reader, and I haven't had an issue since.
There are many issues where a scan tool will be required to diagnose the problem, but there are many that you can trace using a simple code reader.....
Old Mar 3, 2010 | 08:57 AM
Schuby's Avatar
Schuby
ok...I scanned it for codes and it came up with P0300 Random/multiple cyclinder misfire.
Any suggestions on next couse of action???
Old Mar 3, 2010 | 09:33 AM
redwood's Avatar
redwood
Have you ever changed all the COPs? Sometimes you can change just the boots and wires on the bottom of the COP that hooks to the plugs and that'll fix it.
Old Mar 3, 2010 | 09:36 AM
Schuby's Avatar
Schuby
I was just googling that exact thing. I know the bottoms of some of the boots are cracked...i remember that when i changed the plugs. I think i will try that. I can get 8 for around $30.00 online. Sound good to you?
Old Mar 3, 2010 | 10:42 AM
redwood's Avatar
redwood
Had a 99 2wd with a 4.6 that went through boots and wires like underwear. COPs were always good..........
3/4ton4X4
Jun 25, 2014 05:07 PM
jjoyce11
2004 - 2008 F150
May 27, 2012 07:39 AM
89toy
Aug 14, 2009 06:17 PM
6ohin25401
Dec 9, 2007 08:04 AM
gdolson
1997 - 2003 F150
Oct 22, 2002 08:25 PM
