EGR Delete vrs Newer EGR Cooler?
I'm getting ready to order my EGR delete kit for my 04 6.0. But I was wanting to know what the scoop was with this "newer" EGR Cooler?
Ford_Power_Stroke_EGR
Does this "newer" EGR cooler fix all the problems so one doesn't have to do an EGR delete?
Thanks,
Thanks,
I took the plunge
Well, I dove in and just ordered the EGR delete kit.... yikes... I do seem to have a good exhaust pipe (4"). I also have a cooler filter kit to install but will do that after I install the EGR delete kit.
I have an 04, and hoping I dont get any CEL light or pop any codes when I do the EGR delete.
Thanks to everybody for guiding me in the right direction w/my new truck.
Cheers,
Cheers,
Warrenty
Tell me about your warrenty, what's the details of that?
Thanks,
I have an early '03 and I bought and installed the River City Diesel complete EGR delete with a complete (turbo back) 4" Magnaflow exhaust without cat and life is REAL GOOD! That EGR cooler is an EPA piece of junk that is just waiting to give you trouble. However, if you're in a state that has emissions tesing for diesels I would go with the bulletproof EGR cooler since it is a much more beefed up cooler system. Otherwise, scrap it and enjoy the benefits (i.e. better MPG, better breathing and cooler EGTs). Also, you shouldn't get any CEL on models up to '05. The EGR plug just dangles there like it ain't gotta home now! That's cool, cuz I don't like housing parasites! Also, you should install a coolant bypass filter if you haven't done so...
FYI- the '03 sounds like a jet now...not annoying, but whistles proudly!
No, IIRC you don't need a tuner to delete the EGR unless you have an '05 and up...and you'll want to have a tuner to inform the computer that it's gone. The '03 & '04s seem to be just fine...the '05 & '06s will throw a CEL most of the time and '07 and newer need a tuner to address the missing EGR.
Lastly, I don't plan on boosting my truck so my system is fairly stock, but if you boost yours, beware not to go too far as you'll be driving a timebomb if you overdo it. Then, you'll be in for a cab-off head stud replacement...ouch! However, once you have the EGR deleted and the ARP headstuds installed, you're kinda ready to unleash hell with horsepower. I'm just trying to go as long as possible on my factory headgaskets and head bolts.
I dont know
Most people say if you have an 03 or an 04 no codes or CEL will come on. However if they do, I'm told you can reconnect the EGR valve and this "may" trick the trucks computer in thinking everything is back installed. If this doesn't work then from my understanding you will have to get a tuner.
But, don't go by what I say, I'm still new at the 6.0 and all this tech stuff.
The truck still has the factory 5year/100,000 mile warranty. It wasn't purchased until June of 2005 therefore that's when the factory warranty started. I just bought the truck about a month ago and while in the dealership getting an oasis report, the service tech told me to not do anything to the truck until after June.
Help me out on the after warranty EGR delete. Will I need to do anything with the oil system along with the EGR delete? I'm still trying to absorb all the info that I have been reading so I apoligize for the lack of knowledge with the delete process. I realize the coolant filter is a must but not sure about the oil side of it.
About the question on oil cooler work, I can speak from the voice of experience on this one. If you are taking the time to delete the EGR on a driven vehicle, the only way to know if you will have an oil cooler failure soon is to monitor oil temp/coolant temp differential. Anything more than 15 degrees indicates a diminished flow through the oil cooler and impending failure. I deleted my EGR and did not understand this. 18000 miles later the oil cooler let go. I have installed a new 06 engine in my truck that has new delivery miles only. I have an Edge Insight monitoring the temps. On a recent trip of 1100 miles, this new engine is running only 4 to 5 degrees difference in the oil/coolant temps. This tells me that when you run these engines without a coolant filter the degradation of the flow through the cooler begins immediately. My experience tells me that when you work on the EGR cooler, whether deleting or upgrading, an oil cooler rebuild is wise. The coolant filter is just as good a decision. I checked my coolant filter after 350 miles before I left on the trip and it was already plugged up, no flow. I will be checking it again today and expect it will need changing. My 2 cents worth
Regards
Regards
