fuel questions help please!!!
Old Mar 1, 2010 | 08:19 PM
lukeg's Avatar
lukeg
Hey felllas new guy here! I have been working on a 68 f250 crown vic front end swap.Going to put the 4.6 out of the car and into the truck.Getting a wiring harness made for the efi. My problem is im not to sure about is the fuel system??? We are getting a aluminum rear mount tank made and im not sure if i should use the stock fuel pump out of the car? If i would need a return line?Preasure regulator? The computer is getting burned to get rid of the emmisions.Some insight would be greatly appreciated!!!!Thanks in advance!!!
Old Mar 2, 2010 | 04:50 AM
jowilker's Avatar
jowilker
The more things that you can bring from the car to run on that engineered system the better off you would be. IMHO
The computer is going to control all aspects of the system, so I hope you are on top of computer burning as you call it.
John
