Fuel leak---
Old Mar 1, 2010 | 06:13 PM
twister23's Avatar
twister23
Fuel leak---
02 f350, leak started after temps hit 35 degrees. i am in s. florida, i think its from the dump valve but not sure. i worked the valve some and it seemed to stop, but now its smelling again. any ideas?
Old Mar 1, 2010 | 06:26 PM
canoechris's Avatar
canoechris
if you do a search for guzzle's Maitenance I think you will see discription of that repair. You can also order the O rings. Great guy to do buisness with.
Chris
Old Mar 1, 2010 | 06:36 PM
twister23's Avatar
twister23
who is guzzle?
i am new to site
Old Mar 1, 2010 | 06:41 PM
big poppa's Avatar
big poppa
Look in back of the fuel bowl, these things, drain valves have been leaking like crazy this year, even in the southern states because of global warming Anyways, heres a link, Replacement O-rings for Ford Diesel Engines and check to make sure thats your problem, you also have lines going into the fuel bowl and they need sleeves. Order from Bob, he's a great fella and fast shipping to boot.
