more brake trouble
Old Mar 1, 2010 | 03:59 PM
tcervi1028's Avatar
tcervi1028
more brake trouble
My 04/150 started shaking about two weeks ago.Thought i was on the rumble strip,could`nt find anything wrong,it went away.Today at hyway speed it started again.Only thing I could find was alot of heat comming from front drivers side rotor? Could the caliper "dragging" cause this kind of viberation?
Old Mar 1, 2010 | 04:39 PM
Ted928's Avatar
Ted928
If one front caliper was much hotter than the other, than you found your problem. A well known problem is the e-bake dragging causing massive shaking. Search on e-brake or my name for info.
Old Mar 2, 2010 | 02:07 PM
Twinsdad98's Avatar
Twinsdad98
Well, yes our trucks have had e-brake trouble, but since you said yours is from the front, not the e-brake. But yes, a dragging caliber is your culpert. Our trucks are sensitive to brake roughness and a dragging caliber will warp the rotor.
Old Mar 2, 2010 | 02:11 PM
Ryan50hrl's Avatar
Ryan50hrl
yep.....just to save some cash...
newtakeoffparts.com had some take off calipers a month or two back....
tcreek
Mar 3, 2014 05:53 PM
brian743
Dec 26, 2012 12:41 PM
elmo13
Bronco II
Jul 24, 2008 04:17 PM
briguy
Jun 19, 2007 06:50 AM
Chris Brians
1983 - 2012 Ranger & B-Series
Mar 28, 2004 11:49 PM
