ranger92
Old Mar 1, 2010 | 01:25 PM
David.Parker's Avatar
David.Parker
ranger92
Is the trans. modulator inside or outside trans. housing on this auto. trans? 4 Lt. 6 cyl
Old Mar 1, 2010 | 01:35 PM
aquanaut20's Avatar
aquanaut20
A4LD, has the modulator outside the passenger side of transmission, midway.. may have to unbuckle exhaust to re/re.
Warning, do not drop/lose actuator pin when you pull the old out, you will need it install with the new.
Do you have fluid coming out the vacuum line??
Did you vacuum test the line??
Old Mar 1, 2010 | 02:48 PM
David.Parker
ranger92
Its a 2 wh drive and yes there is t. fluid going into the intake and it smokes when i start it. I have to put t. fluid in every 2/3 days.
