Sponsored by: Real Truck
99 7.3 need info
Old Feb 28, 2010 | 07:16 PM
bigdawg69's Avatar
bigdawg69
99 7.3 need info
pulled trans 4 other work but ? is truck didnt run when bought i can turn engine by hand at flywheel is this normal?
Old Feb 28, 2010 | 07:20 PM
driximus's Avatar
driximus
I used a Breaker bar and socket on the front and turned it. They make a tool that grabs the teeth on the flywheel also so you can turn it that way.
Old Feb 28, 2010 | 07:23 PM
driximus's Avatar
driximus
Nevermind miss understoon you. No that is not normal The compression of the Cylinders is pretty high on a diesel. sounds like you might have the glowplugs out.
Old Feb 28, 2010 | 07:27 PM
bigdawg69's Avatar
bigdawg69
glow plugs and injectors still in
