c-6 tranny problem
Old Feb 28, 2010 | 10:00 AM
1993 E-150's Avatar
1993 E-150
c-6 tranny problem
i have to idle awhile to let the tranny warm up before D will work, i put it in D and let it warm up and when its ready it will grab. i am thinking torque converter. any ideas? i tried searching here but search is use less it brings up stuff totally different fromm what i typed. thanks
Old Mar 2, 2010 | 06:23 AM
94van's Avatar
94van
Sounds like the internal seals have gotten old, dry, and hard, and don't seal properly when cold.
After the transmission fluid warms up, the seals soften somewhat and seal better, then the trans seems to shift peoperly. Is the fluid level is up to snuff?
What does the fluid look like, muddy, burned smell, red?
It's possible a fluid change and torque converter drain could help.
More than likely, it's due for an overhaul
Old Mar 2, 2010 | 06:40 AM
1993 E-150's Avatar
1993 E-150
i changed the filter and fluid twice, it still looks dirty. i'll have to check and see if i have a drain plug on the tourque converter i know some do and some don't and try draining it.
Old Mar 3, 2010 | 02:24 AM
tiap's Avatar
tiap
An old trick is to put a couple of ounces of dot 3 brake fluid in.
Did that to a c6 years ago and it went annother 75000 miles.
You have nothing to loose.
