Geting ready to put the rebuilt water pump back on, so I can move the truck in and out of the garage to work on it. Question is this: Should I just put the gasket on, or should I use like a permatex type of stuf with it.
Tee hee. Hope I didn't sound like I was being insulting. On my truck, the PO used that stuff instead of gaskets. It worked pretty well, except every place it leaked!
Personally I prefer the old standard, Indian Head Gasket Shellac, for water pumps. It will stick a gasket on like glue, great for positioning, but seals against water very effectively with only a very thin layer. It is alcohol-soluble (when it gets on your fingers).
Yeah, that's the stuff I was talking about, just couldn't remember the name at the time. I have a jar on the shelf I use for most of my gaskets.
I also prefer the shellac type sealants, however, if the mating surfaces are in good condition, I don't think sealant is very necessary. Usually, I will use sealant on only one surface and apply a thin coat of antifreeze or oil on the other side of the gasket to soften it up a bit. This way I can easily take things apart again and often reuse the old gasket.
