Ford AOD trans in a 77' 2WD 150?
No,
__it won't bolt in.
Should you can get to fit. It can handle the bigger "engine".
If you keep your foot out of the G-tank.
& you'll need to install a transmission cooler,
as with any transmission that is doing Tow/Haul duty.
A good place to start in looking for a transmission is Monster Transmission.
Reliable transmissions, & good people.
__it won't bolt in.
I would like to install a 302 with an AOD in my 74 2wd F100 that came with 3 on the tree. My primary concern is the drive shaft. My truck currently has the 2 piece drive shaft and I am wondering if I can run a one piece shaft or if I have to use a 2 piece unit. Can anyone answer this for me?
LARIAT 85
'80-'86 HOWTO's
30
Mar 24, 2026 01:09 PM
Old Hickory
Nov 7, 2016 10:35 AM
LARIAT 85
27
Aug 9, 2016 02:55 PM
07CVPI79F302
Apr 8, 2016 10:11 PM
juice90
Apr 25, 2009 01:53 PM
