level kit camber way off
Old 02-27-2010, 05:16 PM
allen03's Avatar
allen03
allen03 is offline
just got back from the dealer for a alignment after new ball joint upper and lower and a 2" level kit. truck was way out of wack. needed new different pitch camber sets. is that normal? its a 2wd, 2000 f350 dually. just seems like it wouldnt need that much work or parts. anyone been down this road?
Old 02-27-2010, 06:06 PM
banjopicker66's Avatar
banjopicker66
banjopicker66 is offline
Mine also needed a new camber kit when I replaced all 4 ball joints. I was also surprised, especially since my 2WD is otherwise stock, no lift kit or suspension modifications.
Old 02-27-2010, 06:28 PM
F250_'s Avatar
F250_
F250_ is offline
It is common for shops to recommend adjustable camber kits when replacing ball joints. Been there myself. They're not that expensive, and offer plenty of adjustments in the event of future mods require it.
Regarding the OP's issue. Been there, too. The adjustable camber bushings are not always required, but we are not the only ones who have needed to do this, and I'm also not the only one who had to go one step further with some minor grinding for proper clearance.
I had to not only install dual adjustable camber bushings with my new ball joints and 2" front leveling kit, I also had to grind the ends of the top knuckle arms and inside mating face of the c-frames to allow the adjustable bushings to pull the camber into proper position.
I've attached a PDF which describes the grinding I did, using the bottom ball joint knuckle arm as a comparison of what the top knuckle arm looked like before the grinding.
Hope this makes you feel better, Allen.
File Type: pdf
Old 02-28-2010, 10:35 AM
allen03's Avatar
allen03
allen03 is offline
thanks for the info. makes me feel better.
AggieJeep08
1999 to 2016 Super Duty
07-22-2014 12:59 PM
SoCal949
2009 - 2014 F150
05-04-2014 08:24 PM
friscofordguy
02-14-2012 11:07 AM
Da Mother Ship
04-04-2005 11:18 AM
fishin machine
1978 - 1996 Big Bronco
03-03-2005 09:15 PM
Quick Reply: level kit camber way off
