1988 Bronco XLT question.....
1) Is it only held in by 2 bolts? One on the lower left and one on the upper right?
2) Where is the belt tensioner on this thing? I cant seem to find it....if anyone has an in-depth engine diagram, Id really appreciate it.
Thanks
Mike
The tensioner is just to the driver's side of the alt and down a bit - it's the idler pulley. Just stick a socket on there, I forget the size but 5/8" sounds right, and slack it off. The bolt is reverse thread so no worries on loosening that bolt when you slack the belt.
here is a diagram; ck it to see if it conforms to your friend's layout:
http://www.cybrrpartspro.com/Chilton...28CH01_30.html
fig. 11
