fuel gauge
Old Feb 27, 2010 | 09:23 AM
bigcrunch's Avatar
bigcrunch
fuel gauge
on my 93 f350 460 powered 5speed with dual tanks, when I switch to the front tank gauge stays at teh bottom.
I know the front tank has fuel
1. it runs when switched to it
2. when I go to fill it it is full.
what is the common item that malfunctions???
Old Feb 27, 2010 | 11:06 AM
rla2005's Avatar
rla2005
If the front tank's pump was not turning on I would say the ground connection. But you indicate that works so my guess is the sending unit itself is bad or the fuel tank selector switch has a bad contact.
Old Feb 27, 2010 | 02:21 PM
bigcrunch's Avatar
bigcrunch
it is not the switch, I just tested it for continuity between spades 4 and 5.
How many OHMs should the sender give on full and empty?
1993 F350 4x4 460 5speed the front tank
Old Feb 27, 2010 | 02:27 PM
Roanoker494's Avatar
Roanoker494
Sending unit problems where common in these trucks. My front tank shows well over full all the time but my rear tank seems to work fine. My truck is also a F350, EFI 460 and a 5spd trans. though mine is a 89 model.
Old Feb 28, 2010 | 09:51 PM
bigcrunch's Avatar
bigcrunch
not the gauge or wire from sending unit,
Can the pump\sending unit be removed without dropping tank or lifting bed?
Old Feb 28, 2010 | 10:15 PM
Roanoker494
Unfortunately you will have to do one or the other to get to sending unit. I believe it is easier to drop the tank, when dealing with the front tank. May want to try to siphon off the fuel into containers or directly into the rear tank.
