ATF Fluid
Feb 27, 2010 | 01:07 AM
ATF Fluid
Just wondering what the best brand ATF and how much to throw in my gas tank to lube and clean my injectors?
Feb 27, 2010 | 03:54 AM
how about marvel mystery oil? Or Lucas.
Feb 27, 2010 | 04:29 AM
Lucas Injector cleaner, upper cylinder lube is the way to go. buy it in the qt or gal for best value. They rip you off on the one dose bottle.
Feb 27, 2010 | 03:56 PM
What about just regular old ATF. I think now everyone calls it Dexron or some fancy name. Should I stay away from synthetic?
Feb 27, 2010 | 04:57 PM
Ash-less two stroke oil is another option. I run the Redline Watercraft two stroke oil with a little 85 plus added. But if you go with an ATF synthetic is fine.
Feb 27, 2010 | 09:35 PM
Is it OK to run Seafoam in the diesel fuel and will it clean the injectors
thanks
Feb 27, 2010 | 09:45 PM
Anybody like DEXRON VI ... cause I can get 5 gallons for $120.00
Feb 27, 2010 | 09:47 PM
Seafoam is good stuff without a doubt.
Feb 28, 2010 | 02:06 PM
Seafoam is great stuff, I put either seafoam or a bottle of ATF in the fuel bowl when I swap filters and run some in the tank every once in a while. Doesn't really matter what kind of ATF you put in the fuel though...
2 stroke oil is good too. ATF doesn't really lubricate it more, just cleans it. 2 stroke oil lubricates it.
Feb 28, 2010 | 03:03 PM
So how about Yamalube 2 cycle oil, I have a gallon of it in the garage?
Feb 28, 2010 | 04:28 PM
1 oz 2 stroke to the gallon of fuel..
kawika
49
Jun 23, 2021 11:47 PM
rshep
Feb 6, 2016 08:25 AM
MTEPERA
Dec 28, 2015 09:50 AM
old-rodder
15
Oct 27, 2011 08:18 PM
Chippa
Mar 24, 2005 09:08 PM
1995 ,
2005 ,
350 ,
add ,
atf ,
automatic ,
clean ,
diesel ,
f150 ,
f250 ,
fluid ,
ford ,
fuel ,
injectors ,
powerstroke ,
transmission
