header ?
Old Feb 26, 2010 | 10:58 PM
drunkenrich's Avatar
drunkenrich
header ?
if i throw a set of aftermarket headers on my 93 f250 5.8l, can i use the stock exhaust or do i have to change that to aftermarket too?
Old Feb 26, 2010 | 11:19 PM
wickedklown83's Avatar
wickedklown83
from what i have read on here if you run shorty headers then yes everything stock will bolt up, if you go with long tube headers then its a custom exhaust the whole way
Old Feb 27, 2010 | 09:42 AM
Conanski's Avatar
Conanski
But shorty headers on the stock Y-pipe is a complete waste of time as it will produce no gains so yeah you really need to replace the whole exhaust.
Old Feb 27, 2010 | 07:50 PM
93f250tn's Avatar
93f250tn
+1 if you dont run a new exhaust it wont let those headers give there max potentional because the stock exhaust is VERY restrictive! Your best bet would be to run a 3" Y pipe with a single 3" exhaust or if you like duals you could run a 3" Y pipe with a 3" I-pipe into 2 1/2" or 3" duals or you could do true duals but youll see about the same hp wise but true duals will be alot louder.
Old Feb 27, 2010 | 10:35 PM
Conanski's Avatar
Conanski
That's a bit much.. there's no need for anything bigger than 2.5" pipe once the stock cats are out of the way, besides anything bigger than a 2.5" Y will be difficult to install on a 4x4.
solareclpse2000
Aug 14, 2008 01:59 PM
bigblockbronco
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Dec 13, 2002 01:52 PM
97ExplorerV8AWD
Aftermarket Products
Oct 1, 2002 06:33 AM
97ExplorerV8AWD
Sep 25, 2002 10:58 AM
97ExplorerV8AWD
Exhaust Systems
Sep 21, 2002 10:00 PM
