New guy needs some help!!
Old Feb 26, 2010 | 12:32 PM
liv2hunt's Avatar
liv2hunt
I just replaced the IWE solenoid on my 2005 fx4, but the sound is still there. It sounds like a playing card in the spokes of a bike tire... The strange thing is it only happens when it is cold(about 25 or less). When I put it in 4wd it stops immidately stops. If I take it out of 4wd it starts back within mile or so. What else should I check?? It makes no sense to me what it only happens when it is cold.....Any ideas? Thanks!
Old Feb 26, 2010 | 01:08 PM
liv2hunt's Avatar
liv2hunt
Alright guys....I just blew out the vaccum lines on the passenger side(side where the noise was coming from) and I got a drop maybe 2 of water out....would that be enough to freeze up and cause an issue in cold weather???
Old Feb 26, 2010 | 03:21 PM
liv2hunt's Avatar
liv2hunt
Back to the top
Old Feb 26, 2010 | 07:03 PM
magnet1's Avatar
magnet1
Hey LIV2, I have been going through the exact same thing over the past month, But on my driver side. I have talked to some of the guys about it, And they all told me to replace the solenoid as well. I replaced it with the new style, And still the sound. I went over my check valves and lines; They are all good. I am purchasing a vacuum test pump to go over the actuators on each wheel to determine which one is bad and not holding vacuum. According to what I have read; Its either an actuator, or a CV joint that can make that playing card noise. The actuator's might be bleeding by and grinding the splines instead of fully engaging or disengaging. I never realized it till you said it; But mine are fine when its warmer out, Then make noise below freezing as well. I don't understand that either. Do yourself a favor, One of the first threads in this forum is titled "EVERYTHING YOU WANT TO KNOW ABOUT THE IWE SYSTEM"... Read it, Bookmark it, Or print it. Its a great write up and will guide you step by step through the troubleshooting process. I should have my vacuum pump soon, And if I find my problem, I'll let you know.
Old Feb 26, 2010 | 07:07 PM
magnet1's Avatar
magnet1
Sorry LIV2, The IWE thread I mentioned is in with the Second "READ FIRST" thread in this forumn.
browntown3
Jan 30, 2015 01:38 PM
wolfiemom
Escape & Escape Hybrid
May 4, 2010 08:09 AM
cougarmandan
Jan 14, 2010 11:35 PM
kattdog
Oct 31, 2003 01:52 PM
