Flash done. What do you mean??
Old Feb 25, 2010 | 05:43 PM
kidoo's Avatar
kidoo
Hi, I read in a few forums that the flashes where done
What do you mean by this. Do I have to have my "Flashes" done
Old Feb 25, 2010 | 06:06 PM
utjer's Avatar
utjer
Flashes are when the dealer will reprogram the ficm, pcm, tcm with the latest updates. You do not necessarily need them done. The newest flash does help with cold start issues. It costs anywhere from $80-$100 depending on your dealer.
Old Feb 25, 2010 | 08:14 PM
mh5500's Avatar
mh5500
Can you just get the tranny reflashed?
Old Feb 25, 2010 | 09:55 PM
MoyockPowerstroke's Avatar
MoyockPowerstroke
To a certain extent Yes. If you go to the dealer and ask for a flash (or calibration update) they will update your FICM (Fuel Injection Control MODULE), PCM (Powertrain Control MODULE) and TCM (Transmission Control MODULE)....get the MODULE theme? If there are updates available (there may be or not), then they will be updated when the flash occurs. I had mine done recently at my dealer for only $32.00.
Old Feb 26, 2010 | 05:58 AM
mh5500's Avatar
mh5500
I don't want my ficm done, My truck runs fairly decent. But the tranny jumps a little in reverse and if I take off a little too hard from a stop.
Old Feb 26, 2010 | 09:19 AM
utjer's Avatar
utjer
Just checking, have you made sure your tranny fluid is full? If not, this can cause this.
Old Feb 26, 2010 | 09:26 AM
69cj's Avatar
69cj
A dry slip yoke will also do that and is a common problem.
Old Feb 26, 2010 | 12:03 PM
mh5500's Avatar
mh5500
It's full. I thought it might be a selinoid doing this
