OIL COOLER QUESTION
Old Feb 25, 2010 | 03:51 PM
AJHEATING's Avatar
AJHEATING
OIL COOLER QUESTION
Has anyone ever used there built in tranny cooler in there radiator as a oil cooler. can you? how? Do You use a adaptor between engine and oil filter.I was just wandering because I have a big block radiator and a manual transmission and why let it go to waste. thanks
Old Feb 26, 2010 | 09:15 AM
f100jim's Avatar
f100jim
The problem with the trans cooler in the radiator is that it much too restrictive to use as an engine oil cooler. It is made to take a very small line flowing ATF, which is about as viscous as water when it is hot, at a fairly low flow rate. An engine oil cooler typically has about a 1/2" bore to handle the flow rate and higher viscosity of the oil.
Old Feb 26, 2010 | 09:44 AM
AJHEATING's Avatar
AJHEATING
Thank you for the answer. Thats all I needed to know.
Old Feb 26, 2010 | 08:23 PM
freednighthawk's Avatar
freednighthawk
To answer your other question, yes, you would use an adapter between the filter and block. Called a sandwhich adapter. Pretty much all autoparts stores should have them, but Jegs or Summit have a much much much MUCH bigger selection of them.
Old Feb 27, 2010 | 01:50 PM
F-250 restorer's Avatar
F-250 restorer
I used the oil radiator type. If I did it again I would use copper line, with an electric fan, and keep it as close to the engine as possible. When I put mine in I used soft line, and put it by the radiator. It caused a 10 psi drop in oil pressure.
Old Feb 28, 2010 | 06:46 PM
jimbbski's Avatar
jimbbski
Another method is to install an oil-to-water cooler adaptor where it screws to the block where the oil filter does. Ford installed these on Explorers where the lower radiator hose attached to it and then had another hose coming out that went back to the engine. Depending upon room sometimes you had to run a shorter oil filter to fit the cooler on it. All of the EFI 2.3L Turbo cars from the 80's used a similar oil cooler but the water inlet and outlet was sized for 5/8 heater hose.
My SVT Contour has just such a oil cooler from the factory.
One advantage of this type of cooler is that in the winter your oil temp will not be over cooled as it would be if you used a oil-to-air. Also you do not have to run high pressure lines to the radiator if you went with the cooler in the radiator. You just need rubber hose and hose clamps. The coolers that use heater hose size fittings are the easiest to install as you do not have to have special radiator hoses that the Explorer used.
Old Feb 28, 2010 | 08:58 PM
phyrekitsune's Avatar
phyrekitsune
jimbbski, I might mention that there are oil cooler install kits available from brands like Hayden that use a thermostatic valve to bypass the cooler when the oil is cold. This, I would think, would prevent overcooling the oil in winter.
Old Mar 1, 2010 | 06:42 PM
jimbbski's Avatar
jimbbski
I didn't mention it but that is another way to control over cooling the oil. I just happen to have 2 of those type of oil cooler adaptors myself. I use one on my road race car with an oil-to-air cooler mounted in front of the radiator and I ended up with one from someone else's project that I aquired.
Frijole
23
May 24, 2016 10:11 PM
Da_Lariat_Chariot
Oct 16, 2015 07:35 PM
TonyG
Oil & Lubrication
Apr 21, 2013 11:06 AM
ssquints999
Jan 28, 2009 06:51 PM
jav409
21
Oct 31, 2005 04:05 PM
