flexplate
Old Feb 24, 2010 | 07:50 PM
gumper 123's Avatar
gumper 123
flexplate
I have a 1992 f 350 w e4od i need a flex plate any ideas where to find one.
Old Feb 24, 2010 | 07:56 PM
starmilt's Avatar
starmilt
Try this guy he goes by partsguyed he has a reputation for being a super guy to deal with and good prices too.
www.partsguyed.com
Old Feb 24, 2010 | 08:14 PM
gumper 123's Avatar
gumper 123
flexplate
Thank you this is a hard part to find
Old Feb 26, 2010 | 09:05 AM
gumper 123's Avatar
gumper 123
ok i am realy cofused got my trany back e4od 1992 f 350 4x4 the new tourqeconverter has 6 studs the old one had 4 the salesman said all diesels have six that i have wrong flex plate. Found a salvage yard 3 hrs away that had 1992 f 350 diesel they pulledit for me when i got there it had 4 holes like the one i have does any one know what is wright
Old Feb 26, 2010 | 09:34 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by gumper 123
I have a 1992 F350 w/E4OD. I need a flex plate, any ideas where to find one?
Welcome to FTE
F3TZ6375B .. Flywheel (Flexplate) / Available from Ford / (F3TZ6375B replaced F1TZ6375B).
Fits: 1991/94 F250/350, F(Super Duty) & E350 7.3L A/T IDI non Turbo.
MSRP: $164.53 // FTE Ford Dealer Parts Dept. sponsor PARTSGUYED.COM price: $118.46.
PARTSGUYED aka Y2KFORDPARTS.COM = Ed Olson, parts manager of MILLENNIUM FORD in Seattle WA
Old Feb 26, 2010 | 09:38 AM
starmilt's Avatar
starmilt
I don't know you should check the part nymber number dummy gave you and see what it has.
Which dealer was it that told you they were six studs.
Old Feb 26, 2010 | 09:46 AM
NumberDummy
Originally Posted by starmilt
I don't know you should check the part number number dummy gave you and see what it has.
Ford part numbers are not marked on any parts after 1956.
Some parts have ID engineering numbers marked on them, but ID engineering numbers are different than the actual part numbers.
OP: If the flywheel (flexplate) has an ID number marked on it, post what it is. I can prolly cross reference it to the actual Ford part number.
Old Feb 26, 2010 | 09:48 AM
Lazy K's Avatar
Lazy K
Not an expert so may be talking garbage but I would suspect that you have a torque converter for a Power Stroke.
Old Feb 26, 2010 | 10:07 AM
NumberDummy
ok i am really confused, got my trany back e4od 1992 f 350 4x4 the new torque converter has 6 studs the old one had 4.
The salesman said all diesels have six that i have wrong flex plate.
That's CACA del TORO!
Found a salvage yard 3 hrs away that had 1992 f 350 diesel they pulled it for me when i got there it had 4 holes like the one i have does any one know what is right?
The beetle brained pinheaded salesman is full of scheiss! He gave you the wrong converter.
The 1990/2001 Ford Truck Parts Catalog sez: 6 converter studs: 1995/96 F250/350, F(Super Duty) & E350 only!
Go back and get the correct converter, and tell the idiot to ask any Ford Dealer's part dept what is correct...and what ain't!
Old Feb 26, 2010 | 10:08 AM
gumper 123's Avatar
gumper 123
ok there are two different numbers one on a sticker one on the flex plate... this one is on the flex plate ..F4TP6375AA & this is the sticker on the flex plate.. 1F1821419C1
I agree with you Lazy K, I thought myself they gave me torque for a power stroke.
Old Feb 26, 2010 | 10:12 AM
starmilt's Avatar
starmilt
I hope they will take the converter back.
Old Feb 26, 2010 | 10:22 AM
NumberDummy
See what I just typed in post #9.
You have the correct flywheel (flexplate), but...the wrong converter.
Old Feb 27, 2010 | 07:50 AM
gumper 123's Avatar
gumper 123
well I got the right tourque converter at 4.00pm put it all togather last night my e4od is back up and shifts sweet. Thank you for your help fellows
Old Apr 26, 2010 | 05:15 PM
drz400gncc's Avatar
drz400gncc
will this fit an 86 6.9 wth a c6
Old Apr 26, 2010 | 07:08 PM
gumper 123's Avatar
gumper 123
I am not for sure, but would not think so
wpnaes
Jul 15, 2013 09:18 PM
Worktrucks
15
Feb 2, 2013 11:02 PM
Trulyvintage
1947 and Older Ford Trucks
May 20, 2011 10:40 AM
HiSPL
Testing.....
Aug 19, 2009 05:52 PM
beartracks
Oct 18, 2002 02:20 PM
