Hey all, i have an 89 EB Bronco 302 Auto Aod, I was told that if you drove without the TB cable that comes from the tranny to the Throttle Body, it would mess it up, Well, i did this just about 100 feet, and it happened, Does anybody know what i did, or what can i do to fix what i have done, and does anybody know where i can get the little plastic connector that holds that cable on, it is kind of shaped like a light bulb!! Your guys help is very much appreciated!!!!
100 feet won't hurt anything. The problem with driving without the TV cable is that it can let the tranny slip and burn up clutches. As for the part, it should be fairly cheap from Ford.
I know it shouldn't have hurt anything, but it did?!?!?! So what can i do to fix the thing, this is frustrating as heck, someone told me there is a GURU that knows alot about the AOD So can someone please tell me what is wrong, because it is like its not slipping, i would like to have this fixed sometime soon if at all possible for you guys to get back to me
It starts really hard, like its stuck in a gear, because it lunges if it turns fast enough, will a rebuild help, i can do it myself right?? i need to as i am in highschool and cannot afford to have someone do it for me, i know my stuff about mechanics, because i just rebuilt a 350 motor for my old POS chevrolet, SOOMEONE PLEASE HELP!!!!!
Sounds like you have two problems.
Try making sure the shift linkage is OK and it is in park when you try to start, maybeput it in neutral and try.
If the TV linkage is stuck wide open and the tranny is in drive it may try to lunge forward.
What happened that you took the cable off?
my sister drove it six miles, and it died commin in the driveway, abnd she just told me this!!!!!!!!! What am i to do now? The coupler that held the cable on broke when i tried to take it off!! Any help is greatly appreciated
