functionality issue with ford 2009 150 series
Old Feb 23, 2010 | 05:02 PM
haney21's Avatar
haney21
Our f150 king ranch has a popping noise in the back woofer. We can't even play the radio and it even pops sometimes when the radio is not on. There is a special service message regarding this and it sayd microsoft is trying to resolve the issue. I was wondering if other people are having the same problem.
Old Feb 23, 2010 | 06:53 PM
silver05fx4's Avatar
silver05fx4
Well I never hear of a issue with the rear sub yet, but Sony makes the radio and sub,so I don't know what microsoft would be doing inless the sync is messed up
but take it to the dealer
Old Feb 24, 2010 | 05:31 PM
berry1234's Avatar
berry1234
May or may not apply.
TSB 09-20-10
10/19/09
SPEAKER POP AND/OR RADIO INOPERATIVE/BLANK/LOCKED UP
FORD:
2008-2009 Fusion, Mustang
2008 F-150
2008-2009 Edge, Expedition,
Explorer Sport Trac, Explorer, F-Super Duty
MERCURY:
2008-2009 Milan, Mountaineer
This article supersedes TSB 9-16-3 to update the vehicle lines.
ISSUE
Some 2008-2009 F-Super Duty, Expedition, Explorer, Explorer Sport Trac, Mountaineer, Fusion, Milan, Mustang,, Edge and 2008 F-150 vehicles equipped with Single CD and CDX6 Audio Control Modules (ACM), may exhibit either a speaker pop noise and/or a condition where the ACM is completely inoperative or will not power on.
ACTION
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
The speaker pop typically happens after an extended drive period when vehicle is warm and opening/closing a door; however, it may happen anytime the (ACM) is turned off. Using the vehicle heater through the instrument panel (IP) panel vents (on high setting) may also cause the condition to repeat more often. The ACM may be completely inoperative, blank. or locked up. It may be caused by a software lockup event within the ACM.
Reprogram the ACM to the latest calibration using IDS 63.02 and higher. This new calibration is not included in the VCM 2009.9 DVD Calibration files may also be obtained at the website.
An ACM replacement will be necessary for 2008 F-150 for the above symptoms, it can not be reprogrammed with IDS. Reference Workshop Manual, Section 415-00 for removal and installation instructions. Please specify speaker pop noise/lock up on the 1878 form when ordering a replacement ACM for F-150.
WARRANTY STATUS: Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
IMPORTANT : Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
OPERATION DESCRIPTION TIME
092010A 2008-2009 F-Super Duty, 0.3 Hr.
Mountaineer, Explorer
Sport Trac, Edge, Fusion,
Milan, Mustang:
Reprogram The ACM (Do
Not Use With Any Other
Labor Operations)
092010B 2008 F-150: Retrieve The 0.2 Hr.
ACM Unit Part Number -
Acquire And Order An
Exchange Unit Can Be
Claimed with Operation C
(Do Not Use With Any
Labor Operation Outside
Of This Article)
092010C 2008 F-150: Replace The 0.4 Hr.
ACM, Can Be Claimed
with Operation B (Do Not
Use With Any Labor
Operation Outside Of This
Article)
DEALER CODING
CONDITION
BASIC PART NO. CODE
RECAL 04
shanehanna35
2009 - 2014 F150
Apr 13, 2017 09:37 PM
doczenith1
6.7L Power Stroke Diesel
20
Oct 27, 2016 03:44 PM
1990E150CamperVan
Sep 1, 2015 03:23 PM
PopoAztec
2004 - 2008 F150
Dec 1, 2013 06:40 PM
Tylus
Jul 15, 2009 11:02 AM
