Wrong flywheel
Old Jan 20, 2003 | 06:06 PM
54at50's Avatar
54at50
Wrong flywheel
I replaced a worn 302 (78 block with 28oz balance) with a newly
built 302 (new block). Stock Ford crank (50oz), eagle rods,trw pistons,crane 272 cam (not roller),windsor jr headswith roller rockers. Don't have facility to do the swap so I had a pro do it. From the get go it seemed too rough at idle. Mech. said it was the cam.
The engine builder balanced the entire assy. with a new damper & flywheel.
After a recent visit to the mech. about a different project I discovered he had installed the flywheel off the old 28oz motor on the new motor.(honest mistake,the "old " flywheel had about 500miles since the tranny swap) I've put maby 300miles on this new motor. Just wanting some opinions about how much damage might already be done ... should I pull it & replace the bearings or change the flywheel and run with it. Oil pressure is good, oil is real clean, just don't want to get a few miles on it & end up doing major work.
54at50
Old Jan 20, 2003 | 06:41 PM
desperado_18_2000's Avatar
desperado_18_2000
Wrong flywheel
The engine should be fine, i don't know when or if it might fail, but just check the oil regularly and change it regularly, and all might be good.
Although if it were me i'd inspect a little further and tear into the bottom end, but ask the mech first, incase of any warantees or anything.
