A tough question
Old Jan 20, 2003 | 05:46 PM
frenchie's Avatar
frenchie
A tough question
I'm trying to install a new electric fuel pump on a 1995 EFI 5.0 motor and I can't find a way to get from ford's push to connect fittings on the fuel rail to a standard SAE style fitting. I even work a Eaton/Aeroquip, and the only thing the Aeroquip engineers could think of was to cut the fuel rail or tubing and braze on a fitting. Does anyone have a solution that doesn't involve brazing?
Old Jan 20, 2003 | 11:04 PM
grclark351's Avatar
grclark351
A tough question
why can't you just make a custom hose w/the stock connector on the rail end and the fitting of your choice on the other?
Old Jan 28, 2003 | 12:52 AM
krazdndenver's Avatar
krazdndenver
A tough question
I did this pn an 86 5.0l. You cut the steel line to the fuel rail and flare it with a flaring tool, then with 5/16 (larger or smaller as needed ) flaring connectors you can work with this. Does this help?
Robert
72 F100 Ranger XLT W/86 5.0L EFI W/AOD
www.geocities.com/krazdndenver
Old Jan 30, 2003 | 05:51 PM
frenchie's Avatar
frenchie
A tough question
Thanks! Both ideas are so obvious and should work out well. Don't know why I didn't think of either of them.
Old Jan 31, 2003 | 12:31 AM
krazdndenver
A tough question
Always glad to help
Robert
UNTAMND
Nov 13, 2009 01:40 PM
pigfarmerdk1
Feb 25, 2007 10:09 AM
4fords
18
Jul 23, 2006 02:13 PM
jade79
Jun 18, 2006 11:17 PM
jowilker
Oil & Lubrication
Jun 20, 2001 10:22 AM
