is my PCM for a high or low impedance TCC?
i have a 95 f150....manuf 6/95....im trying to figure out if the original PCM in my truck was originally intended for a low impedance or 'early' TCC or if its set up for a high impedance 'later' type
so far my impression of info is that its a 'low' type, however im having what feels like a 'no lockup' symptom, (good power at bottom end, but a general loss of connected ness at higher RPMs, esp. if im really pushing it) and the tranny WAS changed to one that SHOULD be a high impedance (F4ZP), but upon dropping pan and checking, i find its a low impedance solenoid, meaning someone did the proper swap, i think...so now im stumped, unless the PCM is actually a 'high' type, but from info, that should have damaged the wiring/PCM......
any suggestions?....also, can anyone tell me what OTHER issues could result in the feeling of a 'no lockup' (aside from a burned out torque converter, and how do i tell if my lockup clutch is burned out as well)
still wondering how to tell if my PCM is for a high impedance or a low impedance TCC.....its marked with a F4TP i believe...at least the F4 is right....does anyone know if there were even any F4 (being 94+) 'high impedance' pcms...or were they a different part # altogether..(like F5 or F6 or whatever)
