CODE 32 (302CID EEC IV)
Old Feb 23, 2010 | 06:21 AM
THE BLUE HEAP's Avatar
THE BLUE HEAP
Hi to all,
I still have the hassitation/surging engine problem that I'm trying to solve.
I just replaced the EEC relay, checked all the grounds & referance voltage of the ECM & they are OK, I checked for codes & have a "CODE 32" EVP circuit has intermittently failed below minimum voltage of 0.24 volts.
The EVP sensor is new.
I checked the EGR & it is able to hold vacuum, it's very clean & so is the intake hole, I also made a gasket made from metal & placed it where the EGR connects to the intake & the engine still surges while driving on the street, so my thought is that if the EGR system is OK & I'm still having this surging problem why is the ECM telling me that code 32?
Does any one know what could be the problem?
Thanking you all in advance
