Quick flatbed question
Old Feb 23, 2010 | 09:23 AM
WEST AUSSIE 94 250's Avatar
WEST AUSSIE 94 250
Some fillers I built for my flat bed to combat the slow fill problem. Now I fill at full speed on standard nozzles. I still cant use the fast fill truck nozzles but you live with that.
The blocks you see under the frame rails are some kind of hard plastic similar to the ones used on the body lift.
Old Feb 23, 2010 | 06:03 PM
Otahyoni's Avatar
Otahyoni
What kind or pipe did you use Aussie?
Old Feb 24, 2010 | 03:04 AM
WEST AUSSIE 94 250
The filler necks are original for the first three inches then where you can see the weld it is 50mm id 316 stainless tube. I can get that from work. Then I reduced back down to 40mm and used the original flexible hose to connect to the tank. The breather is 25mm and goes into the tank where the little breather does originaly. No mod needed here just pop out the breather float and use the original grommet with a 1 inch barbed hose tail. It allows the air to get to the top of the filler without foaming the fuel and makes for much quicker fillups. I then fitted a piece of i/4 inch tube to the new breather and reconnected the original breather to make sure the tanks could get air.
Harrier
82
Jul 28, 2023 03:50 PM
slashfan7964
166
Aug 16, 2020 11:08 AM
mramc1
137
Jan 31, 2017 11:53 AM
Greg5OH
Mar 30, 2016 08:33 PM
mgerdau
21
Oct 10, 2015 01:21 AM
