Modular V10 (6.8l)
towing power.. Weak?
Old Feb 22, 2010 | 04:34 PM
1rockhead's Avatar
1rockhead
I used to two with an 05 expedition that would had plenty of towing power. I would climb the cajon pass and stay at 70 with out much trouble. This weekend I had my first chance to tow with my 01 f250 v10. I was not very impressed. I could barely pull up the cajon pass at 50 mph. It towed great other than that. I guess I just thought the V10 would out pull the 5.4? Does it sound like something is wrong?
Old Feb 22, 2010 | 04:45 PM
Pinky Demon's Avatar
Pinky Demon
You definitely got something wrong. Post up some details of your truck including miles and maintenance you have done recently. When was the last time you changed the fuel filter, air filter, and coil ons?
Old Feb 22, 2010 | 04:52 PM
1rockhead's Avatar
1rockhead
I just got the truck a couple months ago and it has 132,000 miles. I have not had a chance to do any maintenance. Searching here it seems that I should change the air & fuel filter, change the spark plugs and clean the MAF sensor. Do you think it just needs maintenance? I will start there.
Old Feb 23, 2010 | 06:41 AM
rustyfuryiii's Avatar
rustyfuryiii
Is it possible an '05 Expedition with the 5.4L and a 4.10 rear end would tow a little bit better than an '01 F250 w/ the V10 and a 3.73 rear end. In other words what I'm trying to say is, is the HP and torque ratings for an '05 5.4L similar to an '01 V10?
Or as the OP stated could a good dose of maintenance be in order?
Old Feb 23, 2010 | 02:09 PM
rustyfuryiii
OK answered my own question...
'05 Expy w/ 5.4L = 300HP and 365ftlbs torque
'01 F250 w/ 6.8L = 310HP and 425ftlbs torque
Maybe a good tuneup is in order. What ratio rear end did/do both vehicles have?
Old Feb 23, 2010 | 04:24 PM
1rockhead's Avatar
1rockhead
I think the expedition had 3.55 gears. I know it did not have the upgraded towing package so what ever was stock.
I have not checked on the f250 yet. I does seem like something is not right though. Around town I do get a little bit of pinging but not bad. I will at least change the fuel filter and clean the maf by this weekend. I want to set a whole day for the plugs just in case.
Ps.. Not sure why I put it was a 01 but it is not it is a 99.
Old Feb 23, 2010 | 05:21 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Don't forget the wheels are smaller, making the gearing pretty close.
If it's a '99, that's very restricted in terms of breathing at the higher RPMs. Even with lower gears like 4.30's, it might not pull as fast as the Expedition did, because it will rev even higher, causing to lose a lot of power.
Post back tire sizes, gears, everything you can about the '99
Old Feb 23, 2010 | 07:39 PM
Fordfanatic4life's Avatar
Fordfanatic4life
not to mention the Expy doesnt weigh anywere near what your SD does.
Old Feb 23, 2010 | 07:44 PM
VAXB's Avatar
VAXB
Also,don't forget the 99's were not as strong as the 01-04 2v motors. I believe the 99's were 275hp and closer to 400lbs. So the 3v 5.4l would probably be a little better.
wfo1955
Feb 7, 2016 10:54 AM
fishintheobx
Oct 21, 2015 01:46 PM
sidewaysstarion
Modular V10 (6.8l)
13
Jul 22, 2014 10:54 PM
rikosintie
Modular V10 (6.8l)
81
Feb 15, 2011 02:03 PM
