Front end noise
Old Feb 21, 2010 | 01:07 PM
psal2's Avatar
psal2
Front end noise
My 2000 4X4 Ranger has a high chirping sound once I hit about 25 MPH. When I brake, it stops but starts again at the 25MPH or higher. At first, I thought it was a brake wear indicator but that should only happen when braking, correct?
It is not clicking so it might not be the CV joint.
Any ideas?
Pete
Old Feb 21, 2010 | 02:38 PM
Rangerman Stan's Avatar
Rangerman Stan
You might want to check the brake pads on both sides anyway. Some of the wear indicator pads I've had made noise even without the brakes being applied. At least that way you can eliminate it as a source.
Old Feb 21, 2010 | 04:00 PM
psal2's Avatar
psal2
Thanks, I intend to but I have the feeling it is the upper or lower ball joints.
