front axle pinion angle
Old Feb 20, 2010 | 05:52 PM
benmoderow's Avatar
benmoderow
I have a dana 44 front axle, the truck is a frankensien. I did a 2wd to 4wd conversion, and made the front axle a coil sprung front end. I'm putting everything back together and the front drive shaft seems to be at quite an angle, just doesn't look right. What is the correct pinion angle, where is the best place to take this angle reading, and what is the best solution to the angle being off? Also, I've heard alot about camber and caster, how do I check this and make sure everything is where it need to be? This is the part of my project where I figured I'd need help, hope you guys can help me, Thanks
