72 Steering Wheel
Old Feb 20, 2010 | 03:12 PM
Phil105's Avatar
Phil105
72 Steering Wheel
Will a steering wheel for a 73-79 pickup fit on a 72 pickup?
Old Feb 21, 2010 | 06:12 AM
Redcat Diesel's Avatar
Redcat Diesel
73 thru 76 will work. 77 I'm not sure since there were a lot of mid year changes. 78 - 79 wheels are different.
Old Feb 21, 2010 | 07:29 AM
Phil105's Avatar
Phil105
Thanks a lot. I've run across a wheel from a 73 that looks nice for a replacement. It's not "correct" as my truck is an XLT with the woodgrain center, but I hear those are few and far between.
Old Feb 21, 2010 | 07:37 AM
Redcat Diesel
Good news Phil105. The woodgrain center from your original wheel will fit into the 73 wheel. You have to remove the center to swap the wheels any way.
Old Feb 21, 2010 | 07:41 AM
Phil105's Avatar
Phil105
HA - well, that's if my center weren't all screwed up!! Think I'm gonna get this one anyway. Believe I saw on NPD they have the woodgrain center replacement.
Has anyone tried to "dye" these wheels? I need a blue one and this one is black. Wonder if they vinyl die you can use on seats would work on these wheels?
Old Feb 21, 2010 | 07:53 AM
Redcat Diesel
I've never tried to dye one but I did paint the 3 spoke 67-67 style wheel I swapped into my 72. I scrubbed the wheel with a good, all surface cleaner and a cheap toothbrush to get the crud out of all the seams. Then I scuffed it with #00 steel wool and applied 2 coats of Duplicolor adhesion promotor. Then 2 coats of paint. I scuffed it with #0000 steel wool between coats.
Old Feb 21, 2010 | 08:03 AM
Phil105's Avatar
Phil105
Thanks again for the info. That's good to know if the dye won't work. I know I dyed the seats in my old jeep a couple years ago and they have held up fine.
Old Feb 21, 2010 | 08:16 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1971/77 F100/350's use the same steering wheel's except for 1975/77 F100/350's with Speed Control.
The same steering wheel's were also used on 1974/77 Bronco's.
1971/73: The steering wheels were originally available in Blue, Red, Tan, Black and Green.
1974/77's were only available in black (D4TZ3600A).
Ford...in the late 1970's replaced the 1971/73 wheels with D4TZ3600A (use w/o Speed Control). It's been reproduced by Dennis Carpenter.
btw: 1971 and later steering wheels use a vinyl horn pad/switch.
1970 and earlier steering wheels use a horn button or horn ring.
Old Feb 21, 2010 | 08:18 AM
Phil105's Avatar
Phil105
1971/77 F100/350's use the same steering wheel except for 1975/77 F100/350's with Speed Control.
The same steering wheel was also used on 1974/77 Bronco's.
Thanks Bill. Gonna give this one a try.
Old Feb 21, 2010 | 08:34 AM
NumberDummy
Same 3 spoke steering wheel: 1961/66 F100/250 2WD / 1966 F100 4WD / 1967/70 F100/350 / 1966/73 Bronco / 1960/63 Falcon/Comet.
Automotive paint supply stores sell paint made specifically for steering wheels.
The 1961/70 black 3 spoke steering wheel (C3DZ3600A) has been reproduced by Dennis Carpenter.
Old Feb 21, 2010 | 08:36 AM
Phil105's Avatar
Phil105
[quote=NumberDummy;8543413]Same 3 spoke steering wheel: 1961/66 F100/250 2WD / 1966 F100 4WD / 1967/70 F100/350 / 1966/73 Bronco / 1960/63 Falcon/Comet.
Does it take an adapter kit or some form of modification to make an earlier wheel fit a 72? I'm no real motorhead so I need to keep it simple.
Old Feb 21, 2010 | 08:59 AM
Redcat Diesel
You'll have to trim about 1/4" off of the end of the steering shaft to make it work. Other than that it's a bolt on. You will however need the horn contact and button to match the wheel.
Old Feb 21, 2010 | 09:00 AM
NumberDummy
I haven't a clue...as I've never been involved in swapping steering wheels.
Old Feb 21, 2010 | 09:08 AM
Phil105's Avatar
Phil105
May be getting to "deep" for me. Guess I'll stick with original style. Bet it would look good though with the older style wheel.
Redcat Diesel
I think I have steering shafts for both in my stash. If so I'll grab a pic and post it to show the difference.
