Definately have a leaking number 4 injector on top side steel fuel line. Im guessing new o-rings will solve this?
Also I was driving and switched to my back tank which I filled up the week before. Fuel guage registered quarter tank. That is a major fuel leak, not on the tank though. Guessing the lines.
Where can I get all new fuel lines including return lines and steel lines? Will I need any special tools?
sounds like you just need a return line kit. You can try to tighten the steel nut above the plastic cap but dont turn it too hard. If it is loose, there is your problem. I would consider a fuel return line kit, it has the orings, tubing, clamps etc etc. Around 30 bucks or so. if you lost 3/4 tank on a return like leak, you would have to notice a massive amount of fuel on the ground when you park and significant fuel smell when driving. I would look it all over. Check it all the way to the tanks and make sure the lines and connections are dry they whole way.
maroondoom welcome to FTE and the idi forum
have you been smelling fuel lately?im kinda wondering if this is one of those backwards return line deals that i have heard of where it pulls fuel from one tank and returns it to the other.has the fuel system had ANY recent work to it?is there raw fuel on top of the motor?also can you give us truck info ......year ,250 or 350 have you kept track of miles driven since your fill up?
