Transgo kit help needed
Old Jan 20, 2003 | 10:02 AM
Mr_Mog's Avatar
Mr_Mog
Question Transgo kit help needed
I bought the E4OD Transgo kit and I have put it in, just waiting to put the tranny back in, but I would like to know what to do about the white spring (Line Boost valve) that is optional depending on what solenoid pack you have.
There are 2 types, one with holes drilled thru the pack, one without. They say if you have the one without, leave the stock spring in, otherwise put in the white spring. Well then on the back page there are directions for a "fix" that asks you to drill the holes in the pack if they are not there. So, my question. Do you put the white spring in if you drill the holes, thus making it a type 2?? Or is there something else different in the pack that they would want you to leave in the stock spring?
Thanks guys!
Paul
