Bronco II Ford Bronco II
water leaking
Old Feb 19, 2010 | 12:16 AM
aqbluegreen's Avatar
aqbluegreen
water leaking
temp gauge shot up on my 2.8 on the freeway today so I pulled to a stop, let her cool down and had little water in the radiator. I filled it up drove home with the engine running really cool, but when I stopped in the driveway water was pouring out somewhere under the engine (not the radiator). I couldnt quite see wher it was coming from but a lot came out. There was a little steam and some hissing as well. Could this be the water pump?
Thanks for any info.
Aq
Old Feb 19, 2010 | 03:44 AM
kernel-panic's Avatar
kernel-panic
Check all of your radiator / heater hoses. Check the water pump. Something tells me you have a ruptured hose and possibly a bad thermostat. Absolute worst case is that you might have blown a head gasket or cracked a head and over-pressurized the cooling system, causing a hose to fail, etc.
Old Feb 22, 2010 | 10:55 AM
mnjettr's Avatar
mnjettr
I had a 2.9 do that, it was the water pump
