Need opinions on surging
Old Feb 18, 2010 | 07:04 PM
hammer65's Avatar
hammer65
Recently in 20 deg. weather, I have found it necessary to take off without letting engine warm up enough. Maybe a minute. At about 40 to 45 mph it started to surge. Never had done this before with 2 or 3 minute warm ups.
After a couple of miles it stops. Is this considered normal, or do I need to have something looked at.
Thanks to all who reply. Jim
Old Feb 18, 2010 | 07:15 PM
Kwikkordead's Avatar
Kwikkordead
When was the last time you changed your oil?
These engines are very dependant on good clean oil for the injection system to function properly.
Old Feb 18, 2010 | 07:48 PM
DieselCamper01's Avatar
DieselCamper01
Any chance it's fuel related? Like a clogged fuel or air filter?
Old Feb 18, 2010 | 08:18 PM
bobpick's Avatar
bobpick
My 1999 7.3 is doing the same thing.Oil and fuel filter changed last week and still surging until it warms up.
Old Feb 19, 2010 | 01:16 AM
FreeDevin's Avatar
FreeDevin
Is the check engine light coming on? If so, do you have any codes?
Does the truck keep doing this after it warms up?
Describe the surging more. Do the RPM's climb with no pressure on the gas pedal?
Old Feb 19, 2010 | 05:24 AM
hammer65's Avatar
hammer65
#1 2500 miles on the oil and Filter.
#2 Could be fuel filter.
#3 No check engine light. The surging came in at around 40 miles per hour, and lasted about a minute or two before going to steady rpm. I haven't noticed anything with my foot off the throttle.
I have noticed a slight surge for a few seconds when I start the engine cold and it then quickly smooths out. It will idle up to 1000 rpm while sitting and warming up. If I touch the brake it will idle back down to 6 or 700 rpm. Thanks guys Jim
Old Feb 19, 2010 | 06:22 AM
flatbeder's Avatar
flatbeder
Jim in colder conditions the truck will idle at 1000rpm to warm itself up. so no worries there mine does that her in AZ if it gets chilly enuff. when you are aproaching the 40 mph mark are you holding the accelerator pedal very lightly is that when the surging occurs? The reason I ask this is because I have the same problems at 40-45 mph. If I speed up the surge will sieze and it will run fine. I spoke with John Wood of John Wood automotive in CA about this problem thinking it could be the t/c. He said look towards the throttle pedal it could have a dead spot on the TPS. I would try to find someone with a AE plug it in and drive it alil and see if you got any codes! Plz keep us posted with any results, for you are not the only one on this forum having this problem it seems a few of us are in the same predicament as yourself.
Old Mar 1, 2010 | 12:13 PM
bkeese's Avatar
bkeese
Everyone says the Throttle Positioning Sensor. Just replaced mine, no change.
If it blows white smoke when it starts back up, it's low on oil.
