Need trailer wiring schematic
Old Feb 18, 2010 | 02:47 PM
Duck Hunter81's Avatar
Duck Hunter81
Hey guys, I am still fighhting a traier wiring problem for my reverse lights and battery charger. My fuses are good, my relays are good so I guess that means its a wiring problem. I need a schematic for color codes if anyone has it. Thanks
Old Feb 18, 2010 | 02:57 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Give this a try Josh. LINK
Old Feb 18, 2010 | 03:17 PM
Duck Hunter81
Thanks Rick but I guess I should have said that I am looking for the truck side wiring.
Old Feb 18, 2010 | 03:25 PM
miller_feed
. I don't have the truck side. Good luck.
Old Feb 18, 2010 | 03:37 PM
PaysonPSD's Avatar
PaysonPSD
Josh,
Go to this LINK. User id is marshall - password is public.
Click LOGIN and then on next page click Auto Repair Reference Center.
Then just navigate to the wiring diagrams.
You need both a battery charge relay and a backup light relay. If your truck did not come with the "Tow Package" you will not have them unless they were added later.
Old Feb 18, 2010 | 03:38 PM
clintbonnie's Avatar
clintbonnie
Looking into truck plug... 1 oclock position + 12v hot.. battery charging , black
3 oclock position R. right turn, brown
5 oclock position ground, white
7 oclock position brakes, trailer, blue
9 oclock position L. turn ,red
11 oclock position running, marking lights, green
Old Feb 18, 2010 | 03:39 PM
clintbonnie
oops.. double post
Old Feb 18, 2010 | 03:55 PM
Duck Hunter81
Originally Posted by PaysonPSD
Josh,
Thanks. The truck cam e with the tow package and had all the relays installed. I did notice that the battery charger fuse was blown so I replace it. Still no power with the truck running. I also checked the relays and could feel them click as the truck was turned on. I also went ahead and traded them out with the ESOF realys with no change. Tha is why I am guessing it is a wiring issue (probbably a chaff). What I need to check is to see which pin power comes into from the fuse box. From there I can also check accesory power (which I am getting cause it clicks) and then the switched power coming out of the relay. At that point I will follow it diwn the wire nad through the connectors. That should help me fix it.
Old Feb 18, 2010 | 05:31 PM
PaysonPSD's Avatar
PaysonPSD
That oughta get the cat skinned. Good Luck.
Hopefully it is just a loose connector at the rear of the truck, or a loose wire in the 7 pin, but it's never that easy.
Old Feb 18, 2010 | 07:33 PM
Kajtek1's Avatar
Kajtek1
On my truck the battery power wire was present at the rear bumper, but was not connected to the plug.
zsir
Sep 13, 2012 05:30 PM
krecak
Mar 21, 2012 06:44 AM
larry2002f250
Nov 12, 2007 09:00 AM
jeffr
Electrical Systems/Wiring
Jul 23, 2000 09:32 AM
