1966 - 1977 Early Broncos
bad fuel pump?
Old Feb 18, 2010 | 12:39 PM
roparsons's Avatar
roparsons
bad fuel pump?
I installed a new fuel pump one month ago in my 75 bronco and it was running fine. Yesterday I had it running while I was flushing the radiator. After running great for about 15 minutes it just stopped and won't start again. I pulled the fuel filter (it screws directly into the carb), and disconnected the hose. I cranked the engine and got no fuel from the line.
Any ideas what the problem might be to just stop like that and then get no fuel???
Old Feb 18, 2010 | 11:41 PM
Boba Fett's Avatar
Boba Fett
Were you running the tank low? Could be junk from the tank.... I would put a clear plastic canister filter between the tank and the carb somewhere and see what gets in there.... you can get them anywhere for a couple of bucks....
Old Feb 19, 2010 | 01:03 AM
roparsons's Avatar
roparsons
Do you have a link to one of the canister filters so I know what I am looking for? I new to the early bronco fixer-upper game. Thank you very much!!
Old Feb 19, 2010 | 06:28 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Just ask at the counter for a 1/4 or 3/8" clear fuel filter, whatever size rubber line you have. Even Tractor Supply has them on the shelf. Get the plastic, not the glass one's.
Old Feb 20, 2010 | 08:42 AM
Boba Fett's Avatar
Boba Fett
should be 5/16.... that is what most factory ford fuel lines are..... here is a link: K&N FUEL FILTERS so you know what they look like.... its a flow through inline fuel filter.... in clear plastic......
mikey112383
1997 - 2003 F150
Aug 31, 2010 02:25 PM
kadrocker
Jan 5, 2010 12:27 PM
fridgeddiesel
36
Jan 3, 2009 08:40 PM
74hiboy
16
Jul 7, 2007 05:18 PM
chipster6
1997 - 2003 F150
Jan 3, 2007 10:55 PM
