squeaky belts
Old Jan 20, 2003 | 12:50 AM
mikeberman's Avatar
mikeberman
squeaky belts
hey i need some help here from u guys. when i have my truck in park or neutral, and rev it up to about 3,ooo, my belts start making this horrible squeek. i just had new belts put on it last july, can u guys help me out?
Old Jan 20, 2003 | 01:37 AM
Torque1st's Avatar
Torque1st
Posting Legend
squeaky belts
Belts need to be tightened after they have run in a while. If they have been squealing too long they may be glazed and will need to be replaced. The pulleys may need to be "resurfaced" with a littlle fine grit sandpaper to make the new belts seat properly. Always re-tighten your belts after initial break in.
Old Feb 3, 2003 | 12:24 AM
Crowbar65's Avatar
Crowbar65
squeaky belts
Mike,
An old shadetree trick my Dad taught me was to rub bar soap on the fanbelts (while the engine is OFF ! ! ).
Cheap stuff is fine, unless you want lilac scented belts.
It has worked for me, but only as an aid to properly tensioned belts.
Take care,
Mike (Another One)
Old Feb 3, 2003 | 02:19 AM
Torque1st's Avatar
Torque1st
Posting Legend
squeaky belts
That bar soap acts as a lubricant. It stops the squeak but it makes the belts slip FAR worse :-(
Next thing you know your battery won't charge or your engine will overheat...
Old Feb 3, 2003 | 11:06 AM
beartracks's Avatar
beartracks
squeaky belts
Really, tighten up the belts to fix the problem. If they are glazed they might be ruined. Avoid the belt dressing sprays. I've seen them cause a knocking sound that sound just like a main bearing.
ericford1984
Oct 1, 2017 10:10 PM
Penn79
May 16, 2014 10:22 AM
Stowie
Nov 13, 2011 09:51 PM
918eva
May 24, 2010 09:16 AM
MiPockets
Aug 27, 2004 06:25 AM
