Daily Driver Down Need Help!
Old Feb 17, 2010 | 06:28 PM
allerickb's Avatar
allerickb
I need help removing the front rotors off my 4WD. The pads have scraped into the rotor and have to be replaced. I was told that a special tool is needed, but the local parts stores around here know what I'm looking for. Any help would be appreciated!
Old Feb 17, 2010 | 06:47 PM
fast70's Avatar
fast70
you need a hub socket and take your locking hubs off first auto zone has them on the shelf or advanced auto , napa
Old Feb 17, 2010 | 07:28 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Do you have the hubs/rotors off?
After you get the hubs/rotors off you drive the studs out with a hammer, seperate the rotor and hub.
Then swap rotors, start the studs back in and finsih drawing them in with a lug nut turned upside down.
Only special tool to remove the hub is the socket to remove the spindle nut on a Dana 50 axle since you have an extended cab.
