76 electrical porblems
Old Feb 17, 2010 | 06:23 PM
coryson87's Avatar
coryson87
Question 76 electrical porblems
I have a 76 f250 highboy with a 360. I did a motor change because the old 360 had a water leak. I recently changed the altenator, coil, batteries (optima red tops) and regulator. The truck runs terrible. When i turn the headlights on it runs a little better, but not much. Someone told me i might have a ground issue. I ran a ground from both batteries to the motor and frame. I also ran a ground from the enigne to the cab and form the engine to the frame. It seemed to run a little better, but still bad. I was wondering if it could be a timing issue. That might not have anything to do with it. I have no ideal wiring is not my kind of thing. Can any one help?
Old Feb 17, 2010 | 06:53 PM
gearhed1971's Avatar
gearhed1971
Check your timing ,should be around 10-12 degrees.
