390 Pistons
Old Feb 17, 2010 | 03:34 PM
79f100six's Avatar
79f100six
390 Pistons
So im freshing up my 390. i took it apart today and found out that it is bored .030 over but it looks like the pistons are the cheap, low compression rebuild kit pistons. I was wondering what would be a decent set of pistons to get that would bump up compression to probably 9.5 to 10.1 range. I'm not looking to spend no more than $200 since i'm on a tight budget and this is not a race motor or anything. Its more of a street motor that gets mudded sometimes that needs a lot of down low torque than high rpm's.
Old Feb 17, 2010 | 03:49 PM
85e150's Avatar
85e150
Go here:
Keith Black Silv-O-Lite Cast Pistons - SummitRacing.com
Silvolite cast pistons with a flat top. These would be the same or similar to a '66 390 regular fuel 2bbl, which was, iirc, 9.5
This will also depend on cc size, head milling, block decking, gasket and a couple of other items.
Basically, you are going back to 1960s car pistons instead of 1970s light truck pistons.
Old Feb 27, 2010 | 01:53 AM
George Frasier's Avatar
George Frasier
MUCH recent posting on this subject . . . 390 crank & rods + 360 pistons. Several aftermarket outlets available for the "overbore" pistons.
Fellenz
23
Dec 8, 2014 04:51 PM
7636074460
May 7, 2012 08:58 AM
hoxiii
22
Oct 27, 2007 07:33 PM
hoxiii
17
Apr 26, 2007 04:37 PM
76f1390
21
Feb 11, 2004 12:26 AM
