Towing Issue
Old Feb 17, 2010 | 02:05 PM
tschoepe's Avatar
tschoepe
Look for a commercial scale in your area, it's usually only $5-6 bucks (at least around here) to weigh in. Lower the jack and disconnect your truck so it's only trailer weight, no truck weight.
Load the trailer as you would for a race, so you get an accurate number.
But keep in mind I was running my Sporttrac at about 110% of Ford's rating for many miles. I even had the "evil exploding" Firestone tires on it for most of the time. If you don't think the truck is being overworked, and you only pulling 70-80% of Ford's rating I wouldn't lose any sleep over it. Change the fluid annually if you want to be sure, then you can find problems before they get serious.
Old Feb 17, 2010 | 03:45 PM
mr. black's Avatar
mr. black
great thanks.
Old Feb 20, 2010 | 05:40 PM
Muddedprairie's Avatar
Muddedprairie
I have an 06 FX4 and i tow alot often with my truck... Have 35 inch tires change the oil every 3k had the trans done 2 times now and i have 75k on the truck... I just added F250 rear Leaf springs to it today. I had helpers on there from JC Whitney and they were junk. So i'm hopping the springs will help me there. I tow a 18 ft car trailer and a 30 ft toyhauler with 2 big lifted quads in it... And no problems or worries here. 8K is fine for your truck.
Mark
Old Feb 21, 2010 | 01:47 AM
bsocko's Avatar
bsocko
I tow a big heavy trailer as well.
Two suggestions, get the 17 inch tires, they will make a big difference (from 20 to 17 would be almost like going to the next bigger size gears in the rears!)
Invest in a Anti-Sway, leveling hitch! It will make your ride much safer and smoother, your truck wont squat much at all then!
shedhorns
2009 - 2014 F150
28
Mar 6, 2017 06:03 PM
ola1234
Nov 23, 2016 09:01 PM
Austin J.
1997 - 2003 F150
Aug 26, 2016 07:00 AM
RandomNewGuy
Nov 13, 2015 09:05 AM
Leadsled Coupe
18
Apr 3, 2004 07:03 AM
