boost gauge fluttering
Old Feb 15, 2010 | 09:27 PM
73pwrstrk's Avatar
73pwrstrk
so i have a fluttering problem at any psi higher then 10psi. its tapped into the map and i put in a brass fitting with ferrel fitting but it still does it. i have a black map which i hear is junk and i should get a gray one. could the map itself be my fluttering problem? or could it possibly be a bad gauge? i have autometer phantom series.
Old Feb 16, 2010 | 12:26 AM
MustangMatt96GT's Avatar
MustangMatt96GT
it seems like all the autometers I know of do that... my ISSPRO does not flutter at all, but my sunpro before really fluttered alot.
Old Feb 16, 2010 | 10:39 AM
foxracing0934's Avatar
foxracing0934
Check to make sure those dam ferrels did not turn a little when you were screwing it together. This is what happened when we were putting the gauges into my buddy's dodge, it still flutters a little bit but I think that is just an autometer gauge thing.
Old Feb 16, 2010 | 01:22 PM
Andy's250's Avatar
Andy's250
i think its auto meter gauges. i was reading that if you take the brass T that you tapped into the map with and jb weld it closed and drill a tiny hole in the jb weld it will constrict flow to the gauge and stop or reduce the fluttering. i havent tried it yet though so idk if it works or not
Old Feb 17, 2010 | 12:55 AM
73pwrstrk's Avatar
73pwrstrk
thanks guys, ill check that ferrel and if thats good ill deal with it for now. want get isspros after i seen my buddies, just waiting on the money.
