Sponsored by: Auxito
fan stuck on
Old Feb 15, 2010 | 08:55 PM
darkmage55's Avatar
darkmage55
fan stuck on
i have a 2001 f150 5.4L 4x4. Today i noticed that the fan would not stop at all. I take it my fan clutch went out? Just makin sure.
Old Feb 15, 2010 | 10:03 PM
fordmerc's Avatar
fordmerc
Do you mean the fan is "howling" at all speeds/rpm, or are you saying that the fan is always spinning?
Old Feb 16, 2010 | 12:08 AM
Bluegrass 7's Avatar
Bluegrass 7
Here is a way to test for fan clutch operation.
Use a good sensitive 'clamp-on' timing light around any fuel injector cable that will trigger the light.
Aim the light at the fan blades.
When the motor is running up to temperature, watch the blades change speed as the thermostatic clutch dis-engauges and engauges over 5 or more minutes in response to temperature changes caused by the thermostat opening and closeing.
If there is no change in speed the clutch is locked up and may need replacement.
The appearence you should see is a stroboscopic visual effect of motion in time with the sampleing cylinder.
Just moving the fan by hand is not alway a reliable indication.
Old Feb 16, 2010 | 02:41 PM
darkmage55's Avatar
darkmage55
no the fan is always rinning, as in it never stops now, and it follows the rpm's so higher rpm's means u can hear it spinning faster
Old Feb 16, 2010 | 07:48 PM
fordmerc's Avatar
fordmerc
Clutch fans never stop spinning as long as the engine is running. The clutch "locks" itself when the heat from the radiator gets to a certain temp range and passes over the clutch. Inside the clutch is a viscous fluid that is temp sensative and changes viscosity depending on temp.
If you are in doubt about your clutch, they are cheap and easy to replace.
Old Feb 16, 2010 | 09:51 PM
darkmage55's Avatar
darkmage55
yea i checked it out today and the fan is not movin without spinning the whole pulley. new fan clutch assembly!
steve340
Jul 6, 2014 11:54 AM
mstiles19
May 11, 2011 09:42 PM
1bad67sbf
2004 - 2008 F150
Oct 4, 2010 06:16 PM
4x4Subaru
Apr 23, 2004 04:03 AM
true4.2
3.8 & 4.2L V6
Nov 24, 2003 02:19 PM
