2wd to 4wd conversion with sas
Old Feb 15, 2010 | 01:12 PM
newfordman's Avatar
newfordman
I am wanting to turn my 82 2wd into a 4wd. I have a 78 bronco chassis. I would like to do a 6" lift as well. Any help would be great. Thanx.
Old Feb 15, 2010 | 08:09 PM
Pkupman82's Avatar
Pkupman82
There are a few SAS kits out there to convert an 80-96 F150 4wd to a straight axle rig. The 80-96 2wd and 4wd F100/F150 frames are the exact same (I know for a fact because I converted my 96 F150 to 4x4 and it was a direct bolt in swap) so any of those kits will work on your truck. I know of a few guys who are crafty with welding a fabrication, have actually built all there own brackets to do the conversion as well. Most of the kits out there use the IFS style spings and have adapters to tie them into the old style front axle. Check out Bronco Graveyard's website, they offer a kit to do exactly what you want.
Old Feb 16, 2010 | 10:29 AM
newfordman's Avatar
newfordman
k. i will check that out thanx for the help
Old Feb 17, 2010 | 10:49 AM
Rogue_Wulff's Avatar
Rogue_Wulff
Originally Posted by Pkupman82
.... The 80-96 2wd and 4wd F100/F150 frames are the exact same (I know for a fact because I converted my 96 F150 to 4x4 and it was a direct bolt in swap)....
This sounds encouraging! I have an 80 F150 2wd, and can get my hands on an 85 F150 4x4 with no motor (rest of the drivetrain is all there) and junk body.
healinhand
65
Jun 29, 2024 12:59 PM
Aremee
Jul 26, 2016 09:57 AM
BigCountry1978
Jun 10, 2016 06:54 AM
goneinsixty
Mar 22, 2015 07:57 PM
RPARKER559
6.7L Power Stroke Diesel
17
Nov 1, 2010 02:53 PM
