5.8 changes through the years?
Old Feb 14, 2010 | 11:33 PM
VintageBlueOval's Avatar
VintageBlueOval
Hey guys,
I'm looking for a replacement longblock for my '65 Mustang. I'm interested in a 351. 5.8s from the mid eighties F and E series seem to be the most common around here. There are plenty of F150s and Econolines from about 75-89 around here, ripe for the picking! My question is, are there any signifigant changes to the 5.8/351 from the mid seventies through about 89? What year did the 5.8 go to a roller cam setup? Will the timing chain cover from my '65 vintage 289 bolt up? I know the intake manifold is 351 specific, but I think all the rest of my accessories will bolt up, including my C4 automatic, correct? Any thoughts on this swap?
Thanks for your time!
Old Feb 14, 2010 | 11:44 PM
skyfox10's Avatar
skyfox10
if you want a roller cam, go as late as possible. seems the block change to accept the roller around 94 and got the actual roller cam around 95.
Old Feb 15, 2010 | 04:01 AM
TexasGuy001's Avatar
TexasGuy001
I would recommend that you go with a 302/5.0 out of a fox body Mustang or similar roller block. Thats what I have in my 65. The 351 is a tighter fit and will potentially make changing spark plugs a pain. Also, the added weight in the front of the car will make it not handle as well.
If you are going to build something with some good power, I would recommend 1 peice export brace, monte carlo bar, and subframe connectors.
Take a look at these forums if you havent already.
http://www.mustangforums.com/
StangNet | Ford Mustang Blog & Forums
Old Feb 17, 2010 | 08:34 PM
ranger6202's Avatar
ranger6202
whether you go 302 or 351, i'd recommend the gt40 heads! and Mass air conversion if you can find it.
92cruisinblue
15
Jul 4, 2013 11:16 AM
camo4evr
May 29, 2012 01:39 AM
VintageBlueOval
Feb 16, 2010 01:16 PM
theGman
Jan 20, 2005 08:42 PM
