timing chain straight-up
Old Feb 14, 2010 | 08:29 PM
mustang81's Avatar
mustang81
I just bought a timing chain with zero degree, 4 ret, 4 adv. I set the crank sprocket at zero deg. I was told the cam(xe-256h) was retard 4 degrees from the manufacturer ? Now i'm confuse where to set the crank sprocket ? 4 advance ?
Old Feb 14, 2010 | 10:05 PM
zaaac's Avatar
zaaac
Comp Cams are ground with 4* advance.
http://www.compcams.com/v002/Instructions/Files/145.pdf
Old Feb 15, 2010 | 09:08 AM
hollenjoe's Avatar
hollenjoe
Yep they have a 4 degree advance built on them for better torque and response, anyways set it at 0....
Old Feb 16, 2010 | 09:10 PM
fordeverpower's Avatar
fordeverpower
yeah, the comps come with 4 degrees advance so install it straight up. The stock cams/timing chains were retarded.
Old Feb 20, 2010 | 12:06 AM
mustang81's Avatar
mustang81
Thanks, i really apreciate it. Don't need to change anything.
Old Feb 20, 2010 | 12:22 AM
dwrestle's Avatar
dwrestle
What does it mean to set the timing straight up?
Old Feb 20, 2010 | 01:13 AM
mustang81's Avatar
mustang81
Set the crankshaft sprocket at 0 degree. Factory crankshaft sprocket is only one place you can set and is 4 deg retard for emission thing. Aftermarket timing chain set can be adjust 4 ret, 0(straight up) or 4 adv.
Old Feb 22, 2010 | 02:12 AM
grclark351's Avatar
grclark351
to be technically correct, the term 'straight up' refers to the intake lobe center line or ICL, not the timing set crank sprocket position
read here under 'Intake Centerline'
LT1howto.com :: Camshaft basic specs and concepts
to install a Comp cam ground 4* advanced 'straight up' you'd need to set the crank sprocket at -4* to counter the advance ground into the cam
Old Feb 22, 2010 | 02:45 AM
mustang81's Avatar
mustang81
Ok, i understand your point grclarck351. Look,in my first post, why i want to set up 4 adv. Where is best to set it on crank to have max hp and torque ? thanks
Old Feb 22, 2010 | 01:17 PM
grclark351's Avatar
grclark351
i'd install the timing set at 0 and check the cam position with a degree wheel to verify that it's where Comp says. short of that, just install it at 0
Obowersox26
Sep 17, 2016 09:21 PM
thomasgreist
General Automotive Discussion
Sep 7, 2015 10:50 PM
scorpion58
New Member Introductions
Apr 30, 2015 04:01 PM
jetrinka
17
Dec 19, 2012 10:25 AM
mustang81
Mar 2, 2008 06:22 PM
