Engine runs like a lean gasser.
Old Feb 13, 2010 | 12:24 PM
superpony18's Avatar
superpony18
Good morning everyone. This has been going on for a while now and I keep putting it off but its the time to figure it out.
here is what AE told me;
KOEO - p0475, p0605
KOER - p0476, p0541
Contribution test - p0269, p0284
buzz test came back clear and all sounded good
Chang rotational velocity - 1).2-1.4 2).9-3.3 3)2.1-5.4 8)4.1-6.6
Is there anything else I should check or watch?
If all you smarter people could please point me in a direction that would be great. Thank you for your time.
Old Feb 13, 2010 | 02:21 PM
danskool's Avatar
danskool
Go Bills !
# P0475 - EPR - Exhaust pressure control valve malfunction - Open/grounded ckt., solenoid open/shorted, failed PCM
# P0476 Exhaust Pressure Control Valve Maffunction
# P0476 Exhaust Pressure Control Valve Performance
# P0605 Internal Control Module ROM Error
# PO541 Manifold Intake Air Heater
# P0269 Cylinder 3 Contribution/Balance Fault
# P0284 Cylinder 8 Contribution/Balance Fault
When i had the last two the new international CPS cured it(269.284). Not sure on the 605.. I got that once before also. But went away also when i canged the CPS.. On the exhaust, I would clean the exhaust back pressure sensor and tube. Not to experienced with codes but here is a bump.
Old Feb 13, 2010 | 02:31 PM
superpony18
thanks for the bump. Ae tells me what the codes mean, I was hoping someone would tell me what the change in rotational velocity meant.
MPD56
6.7L Power Stroke Diesel
1192
Oct 31, 2024 04:40 PM
Sgt93
Feb 5, 2018 12:48 AM
351Cleveland C4
The Next Generation
23
Sep 23, 2013 06:00 PM
retiredinstructor
Mar 20, 2012 05:30 PM
